Hi everyone, while i was flashing 21092016 firmware on my kw88 there was a
Hi everyone, while i was flashing 21092016 firmware on my kw88 there was a problem with the usb connection and now the kw88 smartwatch is dead, does not turn on and when i connect it, in the device administrator shows this: Unknown usb device (device descriptor request error).
¿Is there a way to fix this? ¡Thanks in advance to anyone who can help me!
Normally this means that you’ve killed the boot-loader. This is the subsystem for the watch (like a bios on a PC).
Unfortunately there is no fix for this usually because the device cannot be seen by a PC anymore :frowning:
Are you planning sell?, I would Need strap and housing! just an idea…
@Pablo_Eleven_Pablo11 ​ thanks for your answer!
@Gottfried_TASCH ​ it is a great idea to sell it, the main problem is that i am from Colombia and i don’t know how much does it cost to send it.
Wait if u r lucky you can find a boot loader for your whatch .this is main mtk processor problem if the battery is empty ! The only solution if a genious give you bootstrap flash by serial interface .
oh I’m from Austria, the middle of Europe, so makes no sense I believe…
Anyway thank you
