Hey guys i need you’re help with my d5 i hope this is the right section but the thing i need help with is i updated my firmware today and after i rebooted my watch i saw it was not loading my watch face (black screen) the ismenu the only thing responsive so i can still adjust teh brightness and turn of the watch i hope you guys can help
Er…Did you notice the announcement,alright since you have updated,like Lokifish said, you may flash older firmware to get a functional watch back.
I’m watching (and rewatching) the SmartWatchTicks video… and have downloaded the old firmware… now to install
ah thanks dude i did not read the announcement i have to use flash_tool right ? are there any tutorials on how to do that for the d5 ? @Will_Smith
you can find it on our forum.or NO.1 official website.(there is a course)
http://roundandroidwatches.proboards.com/thread/24/d5-firmware
http://en.001phone.cn/download-39.html
Windows 10 64bit… downloaded the zip (with three folders)…managed to load the USB drivers (found that I needed to use compatibility mode - didn’t see this in the guides)… clicked flash_tool.exe but can’t seem to get past, “The scatter file cannot be found”…
usb compatibility mode? It’s right that on the settings.
Phew!.. I’m up and running again…
How is everybody else?
@Andrew_Davis had to flash my watch this week too, wouldn’t load the battery… Had to try the sptool for about 10 times, each with a different error and was nearly ready to give up - then it just plain worked… Now I got at least my watch back, still no time to toy around with faces atm…
Bro if the menu option is accesible…let your watch’s battery drain then plug charger and remove it…battery is low message appears…select ‘battery use’ and then launcher and clear its data…done.
