Hello, I need help please,
Hello, I need help please, as I can add this disk of days in the clockskin, so that it works in this sphere, I can not find the way to make it spin in 31 servings, Thanks
Why not just make it text?
Ok thanks, just to know if there was any way to do it with clockskinmaker. Thanks again.
You have to use a date array with tilted numbers
here is an example : https://plus.google.com/u/0/111358017962457441786/posts/gywjDfbYz82?sfc=false
(I guess Tim used the same technique; not very clean behind the scene, a bit hard to setup, but the job is done)
