Hello everyone, I have a problem with my x5 after five months in office I put it on to the board before going to sleep and in the morning I find myself with the power-on screen (the one with the clock and the words smartwatch) that intermittently you off and on, he does not respond to any button. I contacted the store where it was purchased and tell me to update the firmware …
First thing to do is remove the rear cover and locate the black&red battery cable. Disconnect it by gently taking off by moving it up and off the board - very important you move it very gently it upwards with something not made of metal. Leave it disconnected for a while and then re-connect and turn on.
Hopefully you’ll be ok. If not - flash the firmware located over on http://roundandroidwatches.proboards.com/board/7/factory-firmware-support and follow the guides.
thanks for the information, which firmware should I download for my x5
@massimiliano_porta
hopefully you won’t need to but the latest is there in the link I gave you it’s an w815 (X5)
thanks again…
Thanks again for the assistance. problem solved … public the photos of my x5 with modified strap …
https://profiles.google.com/photos/105029653849411046278/albums/6340127645013861265/6340127646626683890
@massimiliano_porta
getting an error 404 when I try to access the link…I’m interested in your strap mod…
I used the steel strap for tissot 23mm located on aliexpress, I had to adapt it.
I do not know the link use the application to aliexpress for purchases, you have to work a bit to adapt it with a micro motor and cutters to tungsten, and must be welded inside a small thickness to prevent rotation of the attack, the result is good although again it takes a little work and the precise hand … to the antennas of the original strap I tried to place them inside the case, the signal becomes narrower but still works …
https://profiles.google.com/photos/105029653849411046278/albums/6340182463459770785/6340182462679777874
still not working
- That’s an error.
The requested URL was not found on this server. That’s all we know.
I do not understand, what it refers to the error?
It means it cannot find the file (photo)
