hans65
October 20, 2017, 6:21pm
on my Q7 the heart rate sensor is not working no light is on. Is there something missing?
I checked with adb command and get this:
ULPSH Heart Rate| QuickLogic Inc| version=1 |android.sensor.heart_rate| 0x00000005 | “” | type=87 | on-change | maxDelay=0us |minDelay=0us |no batching | non-wakeUp | last=< 0.0, 0.0, 0.0, 0>
and this sensors:
audio.primary.default.so
audio.primary.mt6572.so
audio.r_submix.default.so
audio.usb.default.so
audio_policy.default.so
audio_policy.stub.so
bluetooth.default.so
camera.default.so
camera.mt6572.so
gps.default.so
gralloc.default.so
gralloc.mt6572.so
hwcomposer.mt6572.so
keystore.default.so
lights.default.so
local_time.default.so
memtrack.mt6572.so
power.default.so
sensors.mt6572.so
vibrator.default.so
Oct 20, 2017 18:21:01 GMT 1 hans65 said: on my Q7 the heart rate sensor is not working no light is on. Is there something missing?
and this sensors:
camera.default.so
camera.mt6572.so
gps.default.so
gralloc.default.so
gralloc.mt6572.so
keystore.default.so
lights.default.so
memtrack.mt6572.so
power.default.so
sensors.mt6572.so
vibrator.default.so
Hi hans65,
Refresh my memory - was the sensor ever working on your watch? Do you know when it stopped?
hans65
October 20, 2017, 8:29pm
3
It never worked, the seller told me, it was working at his store
Oct 20, 2017 20:29:52 GMT 1 hans65 said: It never worked, the seller told me, it was working at his store
you should have asked for a new watch or refund. have you checked if the sensor is connected proparly?
hans65
October 21, 2017, 8:07am
5
No I have not disassembled the watch yet. I hoped based on the result I got with the adb command somebody would see, if the sensor should work
seb84
October 23, 2017, 4:16am
6
normally its soldered to the board, but i also found a loose resistor, when i opened mine earlier.
anyhow soldering those small components is a pain, even with the right tools (i had to do it twice for the resistor, first time was’nt successful
the responsible file i assume is lights.default.so
did you already tried to re-initialize the sensors?
hans65
October 23, 2017, 7:25am
7
It looks like everything is solid connected, but I will check again. How can I re-inializing the sensors again?
Oct 23, 2017 7:25:38 GMT 1 hans65 said: It looks like everything is solid connected, but I will check again. How can I re-inializing the sensors again?
Simple power cycle should do the trick I think
seb84
October 24, 2017, 3:41am
9
i think mtk tools can help
seb84
October 24, 2017, 4:10am
10
hans65
October 24, 2017, 12:03pm
11
Thanks seb84 for your help. Unfortunately the multlitool has no function to reset the sensores, it shows ony the installed. Mtk droid tools dose not work with MT67xx but I found an other tool SpaceMtkTool but here as well no option to reset or reinstall sensors.
I probably have to try to replace the sensor.
But thanks again for your help
