I have the Y3 - 2g works with tmobile - barely…does anyone who has the watch gotten 3g to work?
What band does T-Mobile use for 3G data ?
1700, 2100 uses band 4…1900 uses band 2.
May 9, 2017 5:23:32 GMT 1 thekafka said:
1700, 2100 uses band 4....1900 uses band 2.
The Y3 should have 850 and 2100 only. I guess you have checked that your IMEI number is ok?
i’m not sure what you mean by that. The phone works, it is active with t-mobile and can make calls and texts. What specifically would be a possible issue with the IMEI number?
May 12, 2017 4:31:28 GMT 1 thekafka said:
i'm not sure what you mean by that. The phone works, it is active with t-mobile and can make calls and texts. What specifically would be a possible issue with the IMEI number?
if 3g bands of the watch are supported by T mobile so you should be able to use 3g data, are you sure that 3g data is marked?
yes
May 26, 2017 4:08:19 GMT 1 thekafka said:
yes
have you checked which bands for 3g t-mobile supports? might not supporting 850\2100.
