is posible change “hand bright screen” at other??
May 13, 2017 22:41:07 GMT 1 sclubroca said:
Hi,is posible change "hand bright screen" at other??
Yes you can turn it on or off on gesture setting.
May 14, 2017 6:56:56 GMT 1 ricktop said:May 13, 2017 22:41:07 GMT 1 sclubroca said:
Hi,is posible change “hand bright screen” at other??
May 14, 2017 8:17:36 GMT 1 sclubroca said:May 14, 2017 6:56:56 GMT 1 ricktop said:
i want see other face with turn on in gesture!
Then use my launcher
/thread/758/universal-launcher-new-generation-2?page=1
May 14, 2017 9:08:53 GMT 1 ricktop said:May 14, 2017 8:17:36 GMT 1 sclubroca said:
Then use my launcher /thread/758/universal-launcher-new-generation-2?page=1how do you turn on the hand gesture on your launcher on the lemfo les 1 watch ?
i have turned off the stock gesture but can’t find a way to turn the gesture on with your launcher
May 20, 2017 10:49:51 GMT 1 cosmicma said:May 14, 2017 9:08:53 GMT 1 ricktop said:
May 20, 2017 12:40:33 GMT 1 ricktop said:May 20, 2017 10:49:51 GMT 1 cosmicma said:
at left side of the airplane.
i’m new to the smartwatch world some things are very unfamiliar to me
while i’m here
i seem to get a white screen quite often where the clock face should be
i can still get to the installed apps and settings etc by swiping right but the clock screen remains white and unresponsive
to cure this i have to un install the launcher app and re install which works ok for a while
i have tried both of the latest versions 2.2.1 with and without DPI and they both do the same
any idea what’s going on ?
May 21, 2017 14:29:51 GMT 1 cosmicma said:May 20, 2017 12:40:33 GMT 1 ricktop said:
thanksi’m new to the smartwatch world some things are very unfamiliar to me
while i’m here
May 22, 2017 15:32:02 GMT 1 ricktop said:May 21, 2017 14:29:51 GMT 1 cosmicma said:
while i’m here
Yes i know, bug in the framework, it will be corrected. No need to uninstall, just reboot the watch...
