Gundam Federation RX-78 face https://drive.google.com/open?id=1OXwgZA4PCq86o_2UZIToCDs-NFP4EKlp
hi excellent work but in my Q7 plus do not appear neither the clock hands for the analog time nor the number of steps, why does this happen?
It is the standard zip format and I created with clockskinmaker. It works fine on my lef2. Maybe you can try to reload it or use universal launcher for new gen. I had your problem for some of the clockskin I downloaded.
Works beautifully on my H2.Thank you very much! missing/deleted image from Google+
Thanks, if the battery is not showing up probably, edit the battery X value in the clockskin.xml and you will be fine. The battery bar in my LEF2 position is different so I changed it.
