Its been a while since i posted been doing a lot with .watch format recently but i built this clockskin just so i could pull files from it for watchmaker so i figured i would put it up here since its built.
https://drive.google.com/drive/u/1/folders/1SUcwvFM5gS9LYZEfFvd_fjFInVwaLMTG
ps if you want the watchmaker version here it is. will not work with stock launcher
tap center for auto rotate
I believe you will need to use the one labeled upside-down
.watch files are locked and will have to ask for access.
