Compare this to the original… Can you see what i did?
THE ORIGINAL:
CREDIT: GeraldGenta-Heritage.com
THE ORIGINAL:
The original shows day and your version shows 24hour, right?
Once again, if you head shadows to the pointers would be perfect.
Actually the original does show hours (12 hour format) while mine uses the 24 hour format, but that is not what I wanted to direct your attention. Specifically, I 'fudged" the arc for minutes so I could use WFD to accurately track the minutes using Auto Rotation. Also, I added the GG symbols before and after the minutes sweep in order to achieve a better balance to the design.
Honestly I have never considered adding shadows to the pointers (except occasionally in the case of a second hand.) I’ll have to try that some time!
