Any app that needs accessibility turn on I’m unable to do so…when I go in to on I can’t see the on and off due to the watch screen and I can’t turn my magnification on either because of that
Dec 24, 2016 20:45:29 GMT 1 cody6659 said:
Any app that needs accessibility turn on I'm unable to do so...when I go in to on I can't see the on and off due to the watch screen and I can't turn my magnification on either because of that
try to use mobizen mirroring to access it.
That didn’t work is there any apps that will let me zoom so I can turn the phone zoom on
Dec 24, 2016 23:28:06 GMT 1 cody6659 said:Dec 24, 2016 21:33:32 GMT 1 soniasophie9697 said:
do you have the option to change from round to square? if not look for an update that will fix that. but you need also to install Settings Search.
do you have the option to change from round to square? if not look for an update that will fix that. but you need also to kinstall Settings Search.
I have settings search and I haven’t seen a choice to change the face to square and I’ve been trying days
Dec 25, 2016 15:17:09 GMT 1 cody6659 said:Dec 25, 2016 11:00:14 GMT 1 soniasophie9697 said:
did you update your watch?
Yes it is up to date and I even tried turn my 3rd party app zoom. On and still cant see the car corners to turn the magnification gesture on
Dec 26, 2016 12:26:03 GMT 1 cody6659 said:Dec 25, 2016 19:40:34 GMT 1 soniasophie9697 said:
check again for updates because i know they’ve released few days ago an update for the square option so you should be able to change from round to square display. see if you have the option on display settings.
It says it’s up-to-date and it’s square but when I go In to magnification to turn it on it turns circle even through settings search
Dec 27, 2016 14:48:39 GMT 1 cody6659 said:Dec 26, 2016 20:48:32 GMT 1 soniasophie9697 said:
weird on my x3+ i can access it with or without square display. are you sure that with mobizen it did’nt work? did you tap on the right upper corner to see if it works?
You can flash to the old version and then OTA to the new one. Your latest update missed something which makes your magnification not work.
This is probably bug i the firmware (factory and the lastest). I tried to turn on magnification gesture using PC and TeamViewer, but simply there is no “On/Off” switch, so we can’t do this.
