Does someone have a MTK6580 smartwatch disassembled?
I looking for an image of the PCB on the display side. (opposite of the sim-card side)
Which one - they are all slightly different - for some ridiculous reason.
You can see straight away by comparing the IQI to the KingWear. Battery contacts are different and the shape of the board varies slightly as well. Probably mostly the same though.
In the KW88 it was covered with a sticky foam which was a terrible mess…
@Pablo_Eleven_Pablo11 That doesnt matter, I just need a good image.
Ok, I’ll lift a piece of the curtain… It’s for a clockface.
Just pick a good one. If they are uninteresting, then never mind, I have two here and will use the simcard side.
