Dev chat Pablo & AILIFE
I see - ok.
Yes - the status bar is entirely useless on round watches. But it was causing notification issue because they removed it completely back then.
By the way - I think we have hijacked this topic - so I may move our chat to a different location and leave this for the S99. :slight_smile:
Done - we can chat here :slight_smile:
No and No to your question Pete
but app can still detect it even if disabled
Thanks mate.
Interesting idea to have this switch. I believe that what @AILIFE said about apps knowing that GMS is built into the framework may still cause power draw problems.
As I said though, I can’t really comment until I get hold of a sample. Thanks for bringing it to the forum though, it’s certainly different and this switch is just one example. Further investigation needed :+1::handshake:
Very sad that I can’t get the firmware for this model.
get firmware for 8541 is already a solved problem.
if you dont know how you can ask ai to do it for you, if need fdl i can provide 8541, w377, w527
Well yes and no. I can almost certainly get the generic chip firmware, but the point I have is that it is always better to have the correct firmware for the watch before making any changes. A get of jail free card - so to speak.
Being almost 60 years old, I don’t have the drive and motivation to go through so much agro to get a watch working again after I may cause boot failures….
i mean to ask one that have it to make a full dump
Yes, that’s what we need in the absence of being able to get the stock firmware from the vendor. :+1:
Although, it’s not so easy for most people to dump the firmware.
We would have to post a guide to follow and assure people that firmware dump is harmless for the watch.
can make a sh file that does it for you and put in all in a folder so just run ./dump.sh will dump, no need for second button either
clockskin is super obsolete and bad format it should be long gone i am confidance to say
Understandable I guess.
It’s a solution that was used back in 2014 because it was possible for people to create their own.
If a new, more efficient format comes up then that’s great. As long as people can still create their own without too much trouble.
there are gui tool but it is only available for windows…
Yep, that’s awesome and if I had one I would be happy to do it.
Problem is that I don’t have one and the only person I know who does is @Dr_Andy_Vishnu
I’m not sure if he would be up for doing this?
he struggle using adb so i dont think so
That’s fine. Our WatchFaceDesigner software is made for Windows too.
I think that would be acceptable.
It’s just a matter of persuading the solution providers to adopt it, and the customers of course :+1:
Actually, he’s pretty good with adb.
Unfortunately there is a driver problem on his machine since he got the S13. But usually he’s pretty good on that score.
hate to break it down to you but the watchfaceddesigner is really difficult to use, we are already working on a better one that also uses .watch format( for pc)
