Hi guys
I have a big problem with my watch
A week ago I forgot to charge it,
And day after I was try to turn it on but without succes,
I’ve tried to charge the watch but when I connect it to the charger the watch turn on for a second (with charging logo) and then turned off again.
I’ve already tried to:
disconnect battery
Tried to flash
Tried format + flash
Still watch won’t turned on
Did someone familiar with this problem or have a solution?
Thank guys
disconnect battery
Tried to flash
Thank guys
you have’nt charged the watch for a week? or more? have you tried to leave it in charging for a while to see if it will start charging?
Feb 8, 2017 11:42:21 GMT 1smith said: You may need to charge it again and then flash it.I think your watch need some battery life to flash the firmware.
I tried everythis non of it worked
I’ve flashed the x3 plus firmware but I’ve lost the imei
No signal No GPS and so…
Im starting to get tired from this half baked watches
so the watch can be turned on? when you flashed did you make sure to remove the v mark from preloader?
I’ve tried to flash several times without preloader watch didn’t work
The last time I didn’t remove the preloader and the watch start to charge
Now the watch is working but not imei
I was able to restore the imei
But when I did a factory reset the imei was lost again
I’m thinking about to flash the new ddr3 d5+ firmware maybe it would help
What are you saying?
Don’t know what is DDR, but you could FOLLOW this tutorial to solve your issue.link
