I’m actually considering getting some big beefy resistors and making a current limiter. Or using a digital power supply. I don’t like how fast my watch charges sometimes, since i worry about the longevity of the battery. So i’d rather charge it slowly, at like… 200mA tops. Maybe even 150mA. For the Kospet Hope.
How about this?..
https://www.ebay.com/itm/SENNHEISER-SWITCHING-POWER-SUPPLY-5V-150MA-USB-WALL-ADAPTER-SAW02-5-0-150USC-/152392385723
Maybe you missed it in my post but that is why it is important to use a monitoring device to observe the charge status of your watch, even if you use a limiter. It takes the guess work out of it. And the monitor can check any of the other devices you use, . Because any of these devices can malfunction, including the current limiter.
Sometimes when I left my timer behind, i use an app called as full battery and theft alarm which will keep ringing a loud alarm sound till the charging cable has been disconnected.
MIne is coming soon. CAN’T WAIT!
For what it is worth, I always charge my Kospet Hope Lite overnight and, after 5 months, I’ve had no battery, heat or cracking related problems with it…of course, now that I have read these posts…I’ll stand over it and watch it until it is charged from now on! (Just joking guys!
) Cheers, Doons
OK just got mine in the mail today! NEATO!
Hi all ! I am waiting for a Kospet Prime SE, and i would like to know what to use to charge the batery ?
1 - conect the dock to my mac usb door ?
2 - samsung J4 plus charger ?
Should i drain the the batery till hit 0% before recharge for the first or charger Direct till 100% ?
Many thanks guys!!!
Charge to 100% when you get your watch and charge with provided charging dock to any usb port . This is a great watch
Many many thanks ! I was afraid to use a Phone charger.
It means that the watch as a automatic switch off ? When reach 100% turns off the charge?
I leave mine charging overnight . You will have no issues with charging this watch
Hi, @Dr_Andy_Vishnu, can I call Dr. Anand ?
What about kospet hope does it cut off at full charge ? Thanks in advance.
Best regards
Thats great news!!! Thank you once again.
Hi . Yes it cuts of at 100%
. I am a real doctor you know
Thankyou
Thank you @Dr_Andy_Vishnu , it’s good to know that you are real Dr. my dad and mom were Dr. Is your real name Anand ?
probably his middle name
No its Andrew
Thank you Dr. Andrew
