My Optimus when in bracelet mode is running 2 minutes slow. Is there a way to update the time on the low power mode ? Thanks in advance.
Bracelet mode is completely hardcoded into another microcontroller (not the main MT6739), so we can’t modify any of it’s code.
This will need to be fixed by the manufactufer.
Thanks for replies and info
Solved: If you shut off auto time or time by gps, change time manually; it will fix time for bracelet mode. Hope it helps someone in future
Great. Thank you for sharing this info!
