Hi all, does Bluetooth sucks battery if it is always on and syncing? I’m using M2D apps with it’s companion app M2D Bluetooth manager. I barely have about 8 hrs fun outside when my watch notify me it’s down to below 30% battery…
My Settings.
GPS - Off.
Display Brightness - almost minimum.
No simcard-network on.
Wifi Off.
So what’s your settings to get better battery life or at least hit the 12hrs mark??
Your inputs and suggestions are greatly help around here…!
like you, i use my X3+ connected to my phone with BT. But my companion app is “Watch Helper” and i can use my watch 2 days.
My settings :
Display - Brightness at 10%
Simcard - No
Wifi - Off
GPS - Off
Steps - On
Gravity Sensor - Off
Yes, you can disable it. But I’m not sure if only steps or also HR. Make sure that when you are on wifi close 3g and the opposite that way you’ll get much better battery life. I’ve noticed that 3g consume more battery than wifi.
