Checking the battery panel I see that the major consumption is due to the “phone Idle” cause… most of the time over 80/90%
Ill appreciate any help or workaround to fix this issue because of course it make my phone useless.
sorry for my English.
Ciao
on my watch it shows “phone idle” and i do’nt get battery issues , do you have sim in the watch? try using the watch for a day without the sim and see how it behave.
Ciao
Thank you for your answer.
Do you think is the same keep the sin inside and stay in flight mode?
With flight mode you should get better battery usage but try to remove first the sim and see how the watch behave without the sim, i had bad battery preformence with mtk6580 over the mtk6572 when i used 3g.
I have it in flight mode all day and I didn’t use it at all. After a whole day I got 70% drained due to phone idle again.
I’ll test without sim soon.
