Oct 26, 2017 22:49:37 GMT 1s0unt said:TygrysT , thank you very much! But I tried to Port Telegram and Android Wear.
They both installed but got stuck.
Can you please make stable version?
I really need them, would be very grateful!
I will try, but it is the same problem here how with Facebook Messenger for wear. The wear is connected to the phone, and takes the login from the smartphone, but the wear version does not have any login screen, i thinking for an alternative, like inport it to the wear app from the normal. The same problem is with some wear keyboards or apps that uses Wear GUI, they missing android wear default files, and just crash. they are some problems with the scalling, our watches have different size, compare to the other wear watches, different DPI, and to fix it, we need to remake the whole app :/ on what watch have you tested you app?
Thanks for reply.
My device: Finow X3 Plus (no root)
Can you suggest some list of apps that fully works?
I really like my watch, but OS isn’t quite good. For example, I can’t answer calls or reply on messages.
I even can’t add widgets on home screen, there is only: “Notifications”, “Watchface”, “Weather”, “Health” and “Music”.
“Music” can play, switch or pause music only from watch’s filesystem.
I need some kinda remote for my phone.
I would like to add some “cards”(widgets) on home screen, but I can only access apps in app list through watchface.
Thanks for reply.
I really like my watch, but OS isn't quite good. For example, I can't answer calls or reply on messages.
I even can't add widgets on home screen, there is only: "Notifications", "Watchface", "Weather", "Health" and "Music".
"Music" can play, switch or pause music only from watch's filesystem.
I would like to add some "cards"(widgets) on home screen, but I can only access apps in app list through watchface.
you can't reply to calls and msgs from watch use My SMS for that.
use Eric’s launcher and you can add as much as you want widgets.
the wiiwear and the wiiwatch offers remote control.
Oct 27, 2017 9:04:55 GMT 1s0unt said: Thanks for reply.
you can’t reply to calls and msgs from watch use My SMS for that.
Thanks!
Does anyone know any launchers except Eric’s?
Thanks Sonia, can wiiwear app be usable with the No1 D5? I can find the app for the phone in playstore (wii watch assistance), but do you know where can I find the app for the watch? Believe sender and receiver should use different apps.
i do'nt think you need the app for the watch only for the phone to use it. they are'nt better than the watch helper:)
Oct 30, 2017 7:15:20 GMT 1kotana said: Thanks Sonia, can wiiwear app be usable with the No1 D5? I can find the app for the phone in playstore (wii watch assistance), but do you know where can I find the app for the watch? Believe sender and receiver should use different apps.
but I see it have the feature like remote capture so maybe sometimes it's helpfull. I see someone's video where it's a remote capture application (or option in the app) so I thinks I should have an app in the watch.
Oct 30, 2017 7:18:18 GMT 1soniasophie9697 said: i do’nt think you need the app for the watch only for the phone to use it. they are’nt better than the watch helper:)
but I see it have the feature like remote capture so maybe sometimes it’s helpfull. I see someone’s video where it’s a remote capture application (or option in the app) so I thinks I should have an app in the watch.
Oct 30, 2017 7:25:34 GMT 1kotana said: but I see it have the feature like remote capture so maybe sometimes it’s helpfull. I see someone’s video where it’s a remote capture application (or option in the app) so I thinks I should have an app in the watch.
Thank you for all the info I got from this forum. My small retribution, all free apps ported to run on Amazfit Pace (should run on any round Android watch with Android 5.1 or later):
Thanks for this.
As Sonia says, I guess your ported apps are in the zip on Mega and the real apps are on the play store links?
I will leave this here and as I said - thank you very much
If we get any take down notice I will let you know.
Pablo
Hi, Pablo.
Sure, thank you. All apps are free, I’ve posted the links to the app store for credits, and the compressed file can’t have its content even listed, so it should be fine. If I have to change the post, just let me know (or you can do it, of course).
